The idle adjustment is under the gas door.
It should idle at the same no matter in gear or not.
Make sure you have enough clutch fluid.
Next run a can of Seafoam through the gas for a couple of tankfuls. Finally have the carbs balanced.
Then adjust the idle again.
If it still does it, you are looking for vacuum leaks.
i've tried the idle adjustment , hydraulic fluid , and sea foam , and i have been thinking about balancing the carbs , i also had it checked for vacuum leaks. i guess the carbs are next .
