Do they make an Ignition advancer for the 92 gl1500a and if so where can it be purchased and the cost?
I heard that after you install the trigger wheel you have to burn premium gas.
Anyone know if that is true ?
I installed a 4 deg. on my 88-1500 and have to use at least 89 octane or it pings on hard acceleration or accidently starting in 2nd gear.
Yes it will probably ping depending on the load that it's under(the rpm/and gear that its in). And of couse taking off in 2nd would make a greater than normal load. The pinging is probably true but under light loads it will increase the mileage!
