hi marco, kill switch?
Misunderstood. Sorry.How does he crank it over to check for spark if he has no power to anything:?
Are you sure it isn't in reverse?
Is this similar to what you found ? : http://www.goldwingfacts.com/forums/view_topic.php?id=70485&forum_id=1&jump_to=735292#p735292unbelievable! fixed, (for the moment that is) it is the fuse compartment, not the fuse!, of the starter Relay (switch A near the battery) And why did I not find it in the first place? The fuse is not broken! Let me explain. When checking ignition switch 8-P-BLK I found out that I did have power, only to disappear when turning the key. So it had to be between the battery and this ignition switch. So I checked the starter relay again, but this time opened the whole compartment. To my surprise it was completely melted together! I improvised without the compartment and a charger fused wire. connected and voilá: power, and even started. Now I have to find a new fuse compartment for the relay switch and build my bike up again.
How this all happened over night. I still don't know..... One possibility: near the switch I have a (iron) brake hose for my sidecar, maybe it hit the possitive pole..... I think I'll insulate the the hose this time...
