imported post Could someone tell me if a 1979 ignition system will interchange with a 1976 gl1000
whitehog69 · Premium Member Joined Jul 6, 2005 · 28 Posts Discussion Starter · #1 · Sep 24, 2005 Only show this user imported post Could someone tell me if a 1979 ignition system will interchange with a 1976 gl1000
BRowan · Premium Member Joined Jul 7, 2004 · 1,050 Posts #2 · Sep 24, 2005 Only show this user imported post Are you referring to the ignition switch?
whitehog69 · Premium Member Joined Jul 6, 2005 · 28 Posts Discussion Starter · #3 · Sep 24, 2005 Only show this user imported post No i am referring to the contact points and plate with wiring
Eamonn1200 · Premium Member Joined Jul 7, 2004 · 596 Posts #4 · Sep 25, 2005 Only show this user imported post The points, advance unit, and points case, gaskets and screws are the same parts numbers for 1975-79 so yes they will fit.
axelwik · Premium Member Joined Sep 9, 2004 · 2,230 Posts #5 · Sep 25, 2005 Only show this user imported post Yep, they'll fit.
whitehog69 · Premium Member Joined Jul 6, 2005 · 28 Posts Discussion Starter · #6 · Sep 25, 2005 Only show this user imported post Thanks much you just saved me a bunch of money
