1 - 13 of 13 Posts
· Just me.
I had my wing runing yesterday, rough but running. Had to keep it choked. Added a little Seafoam to the tank and let it sit overnight. Wen I tried to start it today it ws fuel locked. Pulled the plugs and blew the gas out of the cyls. Dried off the plugs, and she started just like she always did,no choke. Could I possibly have a bad shutoff? Yes it was off over night.
you can remove fuel line from fuel pump to petcock an see if it still leaks. if it was on side stand over nite sounds like float valve was stuck open. trash in fuel system. hope this helps.
think like oldfart1 said float. all cyls.?:action::waving:
:cheeky1: was a question but hey hadn't seen my luck lately:cheeky1::cheeky1::cheeky1::action::waving:
i believe it could be the fuel pump. letting it by pass, however, the needles in the floats should stop this also
mark:waving:
:jumper:learn a long time ago to turn of petcock an he said he did. if it was on side stand side then it filled left side cyclinders. when this starts happening you can bet there is trash involved. once i had this problem off came the carbs for cleaning. you can put a new filter on but tha trash has already hit its mark
· Just me.
Discussion Starter · #9 ·
Center stand, valve off, all cylinders. running great today. Love Seafoam.
· Administrator
Gas in all the cylinders, suspect the seal between the plenum halves, and the petcock not shutting off completely. All the float valves leaking is just too much coincidence.
· Postpubescent member
It's possible to get fuel in more than one cylinder with only one float valve leaking. If the bike is on the side stand a right side carb flooding can allow fuel into the plenum and from there it goes right into the left side. I had an '80 standard that did just that. In that bike's case it was the PO who left the petcock open all winter that caused it. A bit of grit can do the job too. That's why any carbureted engine that has a fuel tank mounted higher than the carb should have a shut off valve and that shut off valve ought to be shut off when the engine's not running. That's why it's there, you can't trust float valves not to leak a bit.
1 - 13 of 13 Posts
