1 - 12 of 12 Posts
Discussion Starter #1 (Edited)
I'm a bookmarker kind of guy, okay? I have not read all of these threads from end to end, but I do know that there are a lot of vendors mentioned in them.
I will update this Index as I come across more of them.
These all have been bookmarked into a Big Master Index that covers the whole Steve Saunders Goldwing Forums, an index that you can put into your own web browser by following my Signature Link.
Single Carb Conversions
http://www.langdonsstovebolt.com/store/#!/~/product/category=361512&id=1222026
32/36 weber conversion • NGW Club
4 into 1 carb converson - GL1100
86 Wingnut Honda Goldwing gl1200 Single Carb Coversion and Alternator install - YouTube
GL1100 Single Carb Manifold Option - 1" PVC, Polaris rubber mount, VW Pict 3 style carbs
gl1100 weber 32/36 swap
Juan Fernandez GL1100 single carb conversion
Langdon's Stovebolt | Specializing in Inline Six Cylinder High Performance Parts
Sergey Zavaliy Honda GL1200 (single Solex carb conversion kit) - YouTube
Sergey Zavaliy Single Carb Just Gold Wing... - YouTube
Single Carb Conversions for 4 Cylinder Goldwings
Single Carburetor - which one?
GL1100: Single Carb Conversion
from Alternative Cruisers forum
Single Carb - Copper water pipe manifold
New Design Goldwing GL1000 1100 Single Carburetor Conversion Manifold Kit | eBay
Store | Langdon's Stovebolt Carter Weber Carburetor
Copper Plumbing Pipe manifold... neat & easy to make
Images of goldwing conversion carbs
images of single carb conversion
L.D. Wingnut Single Carb Manifold
Single carb conversion, GL1100
solex 34 pict 3
Need advise. GL1200 Single carb manifold heating
'78 GL1000....Project nearly completed
Single carb kit for GL1200. Own experience
gl1100 Weber 32/36 swap
GL1100 81 Single Carb
4 into 1 carb conversion
My 83 GL1100A home built single carb setup.
Single carb set up JUNK !!!
GL1200 Single Carb
Anyone with EMPI/Solex single carb GL1000 conversions?
Single Carb thoughts, GL1200
Single carb GL1100 install tweaking
Single carb GL1100
1100 carb conversion
ldwingnut single carb conversion kit question
====== More threads found by CM85 ===== added on 8/16/2015
Here are more.
With the way I'm finding them, let me know when you've moved these so I can find more.
GL1200 Single Carb Conversion
Single Carb Conversion + Rigid PVC Intake
GL 1000 run awful, flame-out
GL1100 - Single Carb conversion
81 interstate carbs ???
Norgod32's EMPI Single Carb Conversion
Engine start running really rich, stumbles & backfires through carb, I have spark
Single carb question, GL1100
Update on L.D. Welch (LDWingnut)
Single Carb, GL1100
Single carb curious
Intake manifold design
yes yes yes it works!!
Single carb
Flat spot GL1100
Single carb v. double carb
GL1100 changing to a 2 barrel carburettor?
Single Carb Converson
Backkfired NOW runs like Crap!!
My Goldwing, modifications and happiness!
Single carb on GL 1100
Single Carb Update
Single carb setup
FIve to One, One in Five
carb conversion
Single carb conversion anyone?
CI Single Holley Set UP
Single Carb
one carb or stick with the four
======= more threads from CM85 added on 8/18/2015
here's some more of 'em.
My CC Products manifold carb mounting problems
Weber 2bbl users. Jet Sizes?
GL1000 carb sizes
The broke idiots guide to a new to you weber 32dfta on a goldwing
GL1500 Single Carb
Weber in aggressive modified high output application
GL1000, SINGLE CARB 32/36 WEBER Bogs when accelerating
gl1500se single carb.
Fix this GL1000 motor or find another....?
2 barrel carb swap
2 barrel carb swap
GL1100 single carb install/starter clutch dilemma
Single carb Set up, GL1100
2 barrel carb conversion and Vance and hines exhaust.pics
Single-carb conversions (again) - GL1000
GL1800 Converted to Carb
GL1000 single carb conversion. Weber 32/36 & VW type 3 manifold.
single carb conversion - quickdraw2424
Single Carb Converisions - Flashhawk
8/19/2015 more threads have been found by Steve CM85
see below
http://www.goldwingfacts.com/forums/162-altered-induction/358562-randak-dule-webbers-81-i.html
http://www.goldwingfacts.com/forums/162-altered-induction/356650-weber-carb.html
http://www.goldwingfacts.com/forums/162-altered-induction/356325-alive.html
http://www.goldwingfacts.com/forums/162-altered-induction/354753-weber-single-setup-gl1200.html
http://www.goldwingfacts.com/forums/162-altered-induction/345417-dual-carb-setup.html
http://www.goldwingfacts.com/forums/162-altered-induction/337195-anyone-recognize-single-carb-manifold.html
http://www.goldwingfacts.com/forums/162-altered-induction/336115-anyone-thought-about-cv-carb-each-cylinder.html
http://www.goldwingfacts.com/forums/162-altered-induction/335056-cleaning-lead-deposits-off-32-year-old-wing.html
http://www.goldwingfacts.com/forums/162-altered-induction/335017-3-carb-5-carb-conversion.html
http://www.goldwingfacts.com/forums/162-altered-induction/331633-sporstster-slip-mufflers-gl1000.html
http://www.goldwingfacts.com/forums/162-altered-induction/331943-weber-carb-gl1500.html
http://www.goldwingfacts.com/forums/162-altered-induction/331011-carburator-options-gl1000.html
http://www.goldwingfacts.com/forums/162-altered-induction/330163-my-single-carb-conversion-success.html
http://www.goldwingfacts.com/forums/162-altered-induction/325909-backkfired-now-runs-like-crap.html
http://www.goldwingfacts.com/forums/162-altered-induction/325032-weber-conversion.html
http://www.goldwingfacts.com/forums/162-altered-induction/319845-have-you-thought-about-going-single-carbs.html
http://www.goldwingfacts.com/forums/162-altered-induction/311673-single-carb-conversion-gl-1200-a.html
http://www.goldwingfacts.com/forums/162-altered-induction/305579-single-carb-conversion.html
http://www.goldwingfacts.com/forums/162-altered-induction/301811-gas-milage-goes-sh-t-cold-wheather.html
http://www.goldwingfacts.com/forums/162-altered-induction/301717-carb-conversion.html
http://www.goldwingfacts.com/forums/162-altered-induction/292948-randakk-s-blower-set-up.html
http://www.goldwingfacts.com/forums/162-altered-induction/290557-question-1500-guru-s.html
http://www.goldwingfacts.com/forums/162-altered-induction/287638-there-any-6-cylinder-goldwings-honda-made-4-carbs.html
http://www.goldwingfacts.com/forums/162-altered-induction/283620-gl1100-supercharged.html
http://www.goldwingfacts.com/forums/162-altered-induction/283312-single-carb-conversion-kit.html
http://www.goldwingfacts.com/forums/162-altered-induction/282671-carb-tricks.html
http://www.goldwingfacts.com/forums/162-altered-induction/276084-anyone-know-who-makes.html
http://www.goldwingfacts.com/forums/162-altered-induction/274345-2-carbs.html
http://www.goldwingfacts.com/forums/162-altered-induction/267932-ci-single-holley-set-up.html
http://www.goldwingfacts.com/forums/162-altered-induction/263010-gl1000-carburretor-conversion.html
Midnight 8/19/2015 Scott has found some more SCC threads... twice today!
Probably old news for mosts here
jetting for gl1100 with single carb manifold and solex 30/31 pict
GL1100, what to try now?... single carb project
GL1100, it runs!!.... but doesn't idle well
GL1100 carb conversion..anyone done this
LD Wingnut needs prayers!!!
single carb setup run vid
1981 Goldwing for sale 35K Fresh paint, TONS of work into it
About to give up on the GL1100
Single carb on 1000
carb conversion unit ?????????
Single Carb
Engine dying single carb
GL1100 wont idle
some guys are interested in this single carb setup
New additions to the stable
.... 8/20/2015 Steve has found some more threads... he is putting in a LOT of TIME searching for all of these SCC threads..... thank you steve.
__________________________
Here are more:
http://www.goldwingfacts.com/forums/...88-gl1100.html
http://www.goldwingfacts.com/forums/...rburetors.html
http://www.goldwingfacts.com/forums/...der-wings.html
http://www.goldwingfacts.com/forums/...onversion.html
http://www.goldwingfacts.com/forums/...io-gl1100.html
http://www.goldwingfacts.com/forums/...on-anyone.html
http://www.goldwingfacts.com/forums/...tion-help.html
http://www.goldwingfacts.com/forums/...onvresion.html
http://www.goldwingfacts.com/forums/...78-1000-a.html
http://www.goldwingfacts.com/forums/...-pressure.html
http://www.goldwingfacts.com/forums/...eleration.html
http://www.goldwingfacts.com/forums/...d-you-use.html
http://www.goldwingfacts.com/forums/...-manifold.html
http://www.goldwingfacts.com/forums/...on-1200-a.html
http://www.goldwingfacts.com/forums/...81-gl1100.html
http://www.goldwingfacts.com/forums/...converson.html
http://www.goldwingfacts.com/forums/...nterstate.html
http://www.goldwingfacts.com/forums/...how-check.html
http://www.goldwingfacts.com/forums/...goldwings.html
L.D.Welch is back with His Carb Conversion
Fuel injection
Single carb Conversions, GL1000
GL1000 with 1100 Carb Set conversion issues.
Looking at this single carb manifold
Gl 1000 shuts off during riding
carb convertion
It Is Alive...
Ok finally my turn at single carb conversion
Single carb conversion vs quad carb rebuild
Banned
I'll have more this (and each) evening as I can find them. There's many more threads still to be rounded-up and listed.
I'm finding some old favorite ones I haven't seen in a while.
They're out there. It's like fishing when I find one.
If you're indexing, his stuff really needs to be segregated out and filed independantly.
He has more conversions out there than most realize.
Banned
...many threads of 34PICT-3's not working on 1000 and 1100 engines very well.
This is going to be a larger issue as "Juan" continues to sell them.
Unless he heats below that throttle valve, he'll always have problems.
I do believe that even Sergey (GL1200 conversion) has had problems and was seeking advice on his conversion.
This "Juan" issue is an important one.
Historically, he has presence here that is not well known.
I've an entire evolutionary track of his technical progress up to this moment in time.
Steve updated me again today, we now have 7 pages at 21 threads per page, or 147 Single Carb Threads in this sub-Forum now.
. as always, all of the thread indexes will stay IN the very 1st post of this Sticky Thread.
Steve, CM85 found enough threads to push us over 9 pages of them...
the index, as before, is all in the first post of this thread.
or, you can just simply scan through all of the pages....
that can be more helpful, because I have renamed a lot of them when I noticed that the author did not quite have the thread named correctly....
but that never happens to us, does it? :rofl:
Discussion Starter #12
1 - 12 of 12 Posts
