Hello,
I have a GL1200 LTD and I also saw You-Tube Video and liked this "Landing Gear design much more then the other one's out there. I do not think that the hight and tuck up retracted hight would cause a hindrance in corners. Secondly I am looking for a kit. I am disabled with RA and I have a very hard time at stops and startups with the high center of gravity with the bike. Other then that I would not consider any other make of transportation on and of two wheels. Before the RA hit me I was a 30-year German auto Tech. I am very sure I could make it fit and work on the 1200 from a 1500. I only need one small part that is called THE COMPLETE KIT.
I would appreciate any feed back from you or anyone out there in the procuring the KIT ether new old stock or a non-hacked take off from a 1500.
I have done a lot of work to try to find out any more info on the Landing Gear and I found this info. If any one can find out the owners name or a way to contact the owner of this CO.
Honda Landing Gear NEW ORLEANS LA
Wing Landing Gear
6954 Memphis St.
New Orleans, LA 70124
(504) 288-7975
winglandinggear.com
Please let me know.
Thank You;
Carter
The fellow who manufactured and sold the Wing Landing Gear had his place wiped out in Katrina and no longer makes them. There is another maker of a similar product click the link below for information. They aren't cheap but cost less than a trike. Look at the Retract a Trike. They also make something called Ghost wheels but the retractable wheels look better. The Landing Gear had a speed switch that dropped the wheels automatically at 8mph and retracted them above 8mph. It seems like it should be possible to do that with the Retract a trike setup. It seems to me that it would be safer just in case on forgot to hit the switch.
http://www.trikealternative.com/retractatrike.shtml
Hi,
I know that they were hit. Maybe the name of the ( name ) DBA. :stumped:I have seen all of the other ones but they do not tick under the saddle bags like the Landing Gear. That is why I am looking for an info on Used or some one that has any info on anything on the Landing Gear.
Thanks;
Carter
try this one : bikestotrikesnw.com
YES THIS IS IT............
