1 - 11 of 11 Posts
My 1982 GL1100 Interstate leaks air on the rear wheel between the rim and tyre. The local Honda dealer replaced the valve and reseated the tyre. Now I have put the wheel back on it is still leaking. Is it possible (and safe) to fit an inner-tube to the tubeless tyre. Pumping air every day is such a pain!! Any ideas please - not new wheels - too expensive!
my guess is it would be ok. people use inner tubes on tubeless tires all the time here in the states. just a pain in the butt to put them in. maybe some else might think differently though. or have more info on this subject.
My understanding is that there is too much of a heat buildup that could lead to a blow out. That is based on what little I know about cars.
I know even less about motorcycle tires. Is the answer a new tire or a new rim?
On a back tire on a 1100 so long as you are not running radials or something silly I would not hesitate to tube it. All the 1000's using Comstars require tubes by the book.
Guru
Tubes are o.k. Their drawbacks are heat transfer which will play with your tire psi a little but the main draw back is how fast the tire goes flat if the tube fails when compared to deflation from a nail with a tubeless.
Is your rim the culprit because of pitting? If that is the case, there should be some kind of product to help seal that.
Thanks to you all. Hatchetman, I think I will look at finding a product to seal the rim, rather than go tube. Local Honda dealer is ok but not solving the problem.
I had that problem last fall. Had to clean off corrosion on inside where the tire bead seats. Maybe the dealership mechanic did not clean well / Doug
'83 Aspy Owner's Manual (Canadian version). "Do not install a tube inside a tubeless tire. Excessive heat build-up may cause the tube to burst resulting in rapid tire deflation".
Use caution finding something to clean the wheel as well as lubing the tire for R&R. Solutions containing even trace amounts of lye cause corrosion on aluminum. It appears as a white powder. The commercial products to fix flats and bead leaks WILL cause corrosion. Some of the dealerships are not aware/don't care about this. As you already know replacing wheels can be hazardous to one's pocketbook. Terry
:waving:The above warning is also in my '83 Interstate Onwer's Manual and no doubt is in all GL1100 owner's manuals.
1 - 11 of 11 Posts
