1 - 9 of 9 Posts
I am thinking of installing a 10 disc cd changer in one of the side bag on my 85 aspen. it is one that hooks in through the antenna and you tune in to a certain FM station. it is designed for automotive use. I don't know if the vibration would affect it or not. has anyone installed one? and does it work ok? and ideas?:D
Steve/ hdtp57
· Postpubescent member
What vibration, this is a Goldwing!:whip:
· Registered
Hi hdtp57,
my 10 disc player sits inone of the panniers with some foam under it, other than major pot holes it is fine.
welsh winger
I've had a 10 disc player bolted directly to the inside of the right hand pannier of my wing for 6 years now, with absolutely no problems.
Steve,
I had the same Sony 10 disc unit in the right saddlebag of my GL1100 and all three GL1500's, over a seven or eight year period. No problems, only major potholes would make the thing skip. I made up a quick release bracket so that I could unplug and remove the changer if I needed the extra space in the saddlebag.
I have been listening to a Sony Xplod 10 disc changer for a few years by now and (believe it or not) it hasn't skipped even once. I deliberately got the model that plays mp3-encoded cds (as well as standard cds) because of the large solid-state buffer that's part of that model. The large buffer loads ahead of playing, so you're almost never hearing the signal as it's coming off the disk, always from the buffer which can't skip. There's the bonus possibility of making CDs with about 10 CD contents, if you wan to cary around a lifetime's worth of music, but I almost never do that . . .
I replaced a Pioneer 6 disc unit because it skipped way too often and took all the pleasure out of listening to music for me. The Pioneer operates without skipping in my wife's Miata (not a particularly smooth car), so the Goldwing must have been a harsh environment.
I have the Sony rigidly mounted horizontally in the trunk rather than a sidebag. It's a great unit.
Jack
· Senior Guru
Jack
Motorcycles suspension is always set up harder than a car so that the bike won't wallow all the time, that's just a fact of life even on a touring machine. Most CD players/changers are just not designed to be used on motorcycles so it's great when someone finds a unit that does work. The Sony Xplod obviously works better than the Honda unit in terms of not skipping.
I'm convinced it's the read-ahead buffer that permits it to work so well. I just can't imagine a CD player (or hard drive based player, for that matter) NOT skipping in that environment.
I think that a larger buffer is a feature associated with the capability to read mp3s from disks, and it's possible that other manufacurers' unit will perform as well, as long as they offer the same feature. My only good experience has been with the Sony, though.
Jack
1 - 9 of 9 Posts
