· Registered
My instructions say install compressor 8-10" from where horns will be mounted. I cannot find room to mount compressor(hidden) on the front of the bike. However i have seen many gl1500's with horns under front faring. Where are ya'll mounting compressor? i tried under either side pocket/compartment. Not enough room
Thanks in advance, Skip
Vehicle Motor vehicle Car Automotive lighting Auto part
i put my compressor behind the right turn signal in the faring and ran the hose through the hot air outlet for the radiator on the right side. i made a bracket out of aluminum stock 1''x 1/16 about 8'' long
you can remove the right side pocket and put the compressor in front of the pocket close to the turn signal i used silicon to stick it to the inside of the fairing and tape to hold it in place til the silicon was dry
· Registered
Thanks, i'll try that again to see if i didnt see a way the other day, but it did not look like my comp would fit in there. I guess, its possible, my compressor is bigger than yours.
Thanks again, Skip
btw. thats the look i want!
On my 97 SE I have the two air horns mounted in front, under the fairing, above the front fender.
I removed the left fairing pocket and mounted the compressor in front of it, there is room in there. I then routed the air hose to the horns through a hole drilled through the tupperware.
Love my air horns and they are right in the front where they project the sound nicely.
