1 - 16 of 16 Posts
Bike not starting,did wiring check,OK tested solenoid OK,got starter out,dud, got a new motor.
fiddly to get out or in,but i am told there is a need to rock the back wheel, back and forth to get the starter into position without damaging the reverse gearing,
can anyone enlighten me . .Also would like to know if it should be in neutral,or in gear?,these may be basic questions but i am new to wings
The starter MUST push all the way in by hand, easier with two people. Get a mate to turn the crank with a socket on the bolt under the centre front cover.
If you try to pull the starter in with the mounting bolts chances are you will break a gear inside meaning engine out!
Repeat the starter MUST push all the way in by hand pressure only
It will have to be in gear to turn what needs to turn to get the starter gear aligned.
I agree but Bryan was talking about turning the crank with a ratchet and socket. I bet it turns righty tighty. Too lazy to look. :)
No, it turns lefty on the 6 cyl wings, righty on 4 cyl.
Discussion Starter #11
Hi guys thanks for the info,, but i can only get it to within about a quarter of an inch and no amount of riddle seams to get it any closer ,??any further advice thanks in anticipation
If it is that close the shaft has to be started in correctly. I am kind of hesitant but if it were me I would try pulling it in very carefully. I suspect just a very small amount of torque on the nuts will draw it in. The o-ring might be holding it back especially if you did not lube the o-ring before install. Be careful and use caution.
Could try spinning the rear wheel in gear . Not sure if that will help but it can't hurt.
Try pushing harder, it should go all the way but as said the O ring could be a tight fit
I'm with you Bryan. It is such a hard angle to get any good push on it. It makes me a little nervous but you would think it must be started well in to the spline. Just stuck, huh? :confused:
1 - 16 of 16 Posts
