1 - 3 of 3 Posts
you should be able to use the 769A set . Looking at the specs in Honda service the difference is this....Main air jet primary - #120 the, 771A set is #140
Slow air jet #120 the, 771A set is #130
1993 gl1500, 1976 gl1000
Probably will be okay and you might not notice any difference but it will not be running at optimum performance. Since you have a gl1000 I would recommend this site for info on your carbs.
www.randakks.com
1 - 3 of 3 Posts
