1 - 20 of 20 Posts
I keep getting that message when I submit a post. Accepts post but gives the message every time. ???
I had a number of weird similar issues occur, but once I disabled adblocker and ghostery for this website everything worked fine. Might be worth a try if you have them.
Hey guys,
Some ad blockers interfere with the site, In the past we have found that Adblock plus and Ghostery cause the most issues. That being said, we're working on getting this fixed.
Can you try unblocking [Verticalscope] from your adblock? it should fix the issue and still allow you to use adblock.
Niall
I have been having the same issue lately, maybe for a week and have been using ad block plus for years with no problem.
  • Like
Reactions: dingdong
Magic Moderator
I'm running an Opera Browser with ABP active on this site on a Windows7 machine and everything is working fine.
Junior Grue
If you have a Premium membership there is no need for an ad blocker.:grin3:
Well I have adblocker enabled and have had it forever with no problems. However the last couple of days I haven't had the problem error. ???
Edit: I lied. error just happened again when posting this reply. I'll try disabling adblocker here.
Discussion Starter #10
Testing testing.... with adblocker disabled.
Edit: Didn't happen this time. We'll see.
Let us know if the issue comes back - thanks for your cooperation. :)
Cheers,
Natalie
Discussion Starter #12
Well disabling my adblocker didn't help. Problem still occurring with it disabled on this site.
Just to clarify, you didn't complete disable your adblocker did you? You could have it enabled but unblock/remove our name (verticalscope) from the blocked list or added to the whitelist?
Ghostery - un-select verticalscope in tracking
AdBlock Plus - add the verticalscope to it's white list
Ublock - add static.verticalscope.com and comet-admin.verticalscope.com to it's white list
^^ Let us know if any of these help out and we'll go from there. Thanks for your patience and understanding on this.
Cheers,
Natalie
Discussion Starter #16
No I haven't completely disabled Adblock Plus. Using FireFox with Adblock Plus I have (Disable on goldwingfacts.com) checked. I can't find that page under "options" that you have posted. Under options I only get a check list for example: Show ABP in tool bar.
Has anyone tried the above suggestions? If so, did it help?
Niall
I did and no, it didn't fix it. Doesn't happen every time just sometimes and the forum seems to be really slow loading a page lately.
Niall
It happened just now when I tried to post this.
Junior Grue
I just saw it too and I've had ad blocking disabled for this site for months.
Next time it happens, can you take a screenshot so we can see what it looks like and get it sent to our tech team. Also if you could tell us what browser/device you're using as well.
Niall
1 - 20 of 20 Posts
