Hello,
My name is Scott and I recently bought a 1982 GL1100 Interstate. I have been riding a Reflex Scooter clone for a while and wanted something bigger for long distance cruising. I had a very low budget and so I did a lot of looking. I found this bike on CL and gave the guy $300 for it. I was able to get it home and had to have a new key made. It came with title, but no key. I jump started it and it fired right up. My first ride was short to get the feel for it and see what all it needs. I know I will need to do the fork seals and get a new battery(had to borrow the scooters). I will be doing all the normal fluid changes and brake inspections etc.
As I looked over the bike I was pleased with all the extras to PO had put on this thing. It has Jardine pipes, UNI air filter, Super Brace on the forks, Travelcade seat and lots of extra chrome bits.
So, a few questions.
1. The forks, I know they use air, but I have seem progressive springs available. Is this a good upgrade or should I stick with the air(after rebuild)?
2. My Tachometer still works good, but the glass is missing and it had a chrome trim added, it is missing also. My speedo and center lights have chrome trim. I assume this was a kit, where can I get a replacement for the tach?
3. The headlight just flops, the adjustment knob is not attached anymore, how do I get it out to reattach the adjuster?
4. Were the chrome trim and lights on the front brakes factory installed in 82 or aftermarket? (they cover the calipers and rotor)
5. There are 2 or 3 of the windscreen captive nuts missing, where can I get those?
6. Even after only a short run, the faux tank was real warm and was warm on my legs, is this normal? (not hot hot, just very warm)
So, here is a picture of it, any other things I need to know? I know the side cover is missing over the battery. Is this color Brandywine?
Thank you so much and I look forward to getting to know you all.
Scott
Scott
