1982 Goldwing 1100 Interstate
I just replaced the fuel pump on my '82 GL1100 Interstate. The new pump came with the plastic spacers that go between the pump and the neck and that go between the neck and the cylinder head. In doing so, I tore the thin gasket going from the 'neck' and cylinder head. The plastic spacer is fine. I've assembled without the gasket but with just the plastic spacer. The assembly between the pump and the neck have both spacer and gasket. Do I risk any damage by not having that particular gasket? The old pump has that spacer intact with the gasket that I could swap if need be. Am I safe??
You risk an oil leak.
  • Like
Reactions: limpy45
I just noticed that that particular plastic spacer did not have a gasket on it (the other does). Would I be safe with a thin film of 'form-a-gasket' (or similar) at that joining? Or... I have gasket material that I could cut my own.
A little sealer should be fine.
  • Like
Reactions: limpy45
02 GL1800 w/Auto Pilot
you do NOT want so much sealer on the surfaces, that it will spill over inside the intakes, or other parts of the engine.
a "thin smear" means just that. 1 or 2 thousandths thick.
Discussion Starter · #8 ·
Got it. Off it comes tomorrow for a thin smear. Thanks all.
