1 - 13 of 13 Posts
an aspencade air suspension control on an interstate?
i have the opportunity to get the control box cheap and wondered if there was anything else needed or wether this was an 'all in one' unit and nothing else was used?
Is there any advantage of having the controls as opposed to a manual pump?
Many thanks for any replies to someone that is just learning about 'wings'
Regards Rob
PS how on earth do you manage to write in this box without putting a smiley of some sort in first (hence the silly face at the beginning)
you will also need all the air hoses an fork caps plus anything with the system . its a fun thing to do too. i just use my 20 usd hand pump from progessive spring a lot simpler and less to worry about . just my 2 cents worth----
:waving:I don't think it would be worth the trouble you have to go through to install the complete system. Why not keep it simple and just carry a small hand pump. Never use compressed air to air up the front suspension as you will blow out the seals like I did several years ago. Later on I read in the '80-'83 Honda GoldWing Service Manual not to use compressed air for the forks. I learned the hard way!
Nothing wrong with compressed air if you have a pressure regulator on your compressor but if not I sure agree. The air space inside the forks is so small that it doesn't take much air to shoot the pressure up, and remember you don't want to go much over 10psi.
Piled Higher and Deeper
I think the 1100 book says more like 20 psi max
Depends on the barometric pressure at the time of inflation and the ambient temperature. Of course there's been a lot of devaluation of air pressure in the past twenty years, something to do with the ozone layer and global warming.
I still can't work out how to write in here without a smiley :baffled:
many thanks for all the replies I think I will give it a miss and save the hassle
ATB Rob
I have just realised the smiley i have to put in to activate the text box doesn't appear
Strange things these computers :stumped:
Senior Guru
As far as I can recall the gl1500 max for the forks is 6psi, so it's easy to blow the seals with a compressor.
:waving:Per the owners manual and the '80-83 GoldWing Service Manual the fork pressure for all GL1100's is 14-21 psi. It also states "refill the forks with air manually (all except Aspencade).
My Dad found a neat 12v Sports pump at a garage sale one day for $2. Its yellow and flat about 7x9x3. It has a digital tire pressure gauge thats programmable as to how many pounds you want in you tire. Just push the + or - button till it shows the pounds you want and turn it on. It automatically shuts off every time. I've used it numerous times on tires and checked it with a standard tire gauge and its right on the money. I used it to fill the forks and rear without any problems. Really neat item and it fits the saddle bag perfect,you may want to look for. Garage sales or ebay would be a good place to look. JR
I go out of my way to look for interstates for there simplicity and lighter weight.
1 - 13 of 13 Posts
