Alternately, youcould pack the cylinder with a length of rope (I've taken to using braided poly or that jacketed parachute cord).
y'kinda fill the bore about 1/4 to 1/2 way with the rope, rotate the piston up to press the rope on the back of the valves, and use the transmission (1st gear) to hold the motor in position ... work your valve work, then allow the engine to 'relax, and pull the rope back outta the cylinder (helps if ya tie a big knot or something onto one end; I thread on the top of a water bottle -- so I don't have to go fishing for the rope later)
Cheaper and a lot faster IMHO, of course...
Ask at your local auto-parts place to see if they have a thread-in compression tester kit -- those kits usually have a 12mm adaptor that you could plumb to use as an air-hold (and likely you could rent/borrow the tester and return when you're done too).
