After paying $230.00 for a new metzler for the rear of my 84 aspy and riding a few hundred miles 2-up I began hearing a sqeeking noise coming from the rear of the bike.We had just began a 900 hundred mile ride and could not turn and go home.This noise sounded like a dry wheel bearing so I removed the rear wheel and replaced the bearings,no good the sqeeky noise persisted.I ruled out the rear splines as they had been serviced on a regular basis and looked great as did the drive shaft and u-joint.We finished the trip sqeek and all and made it home safely.When time allowed I again removed the rear wheel,removed the final and drive shaft,cleaned them all up and looked carefully for any issue that would cause the sqeeky noise.Again I found nothing.Before installing the wheel I slid under the rear of the bike for a look,low and behold the tire had been rubbing on the inner fender well in 3 different places on the right side.With the tire on the wheel and using a staight edge and a digital caliper I measured both sides of the tire and the right side was 3/16"wider on the right side!This tire was the same as the one I replaced.Needless to say the honda dealer I bought it from would not help me out with this issue even after they admitted it was a defective tire.If anyone knows of a car tire that would be applicable to a gl1200 please send me a PM.Thanks,moon.
