1 - 13 of 13 Posts
Not strictly Goldwing I know, but I am sure many Goldwing owners have been down this road. I am about to fit a J and M headset into my Arai full face (expensive) helmet. Before I set about cutting out bits of it with a craft knife to accommodate the speakers and microphone, has any body got any advice, tales of woe or other wise words which might assist me?
dont use a knife , get a large washer the same size as the earpiece and get it welded to to the top of a bolt or something like that and then heat it up and then press it into the white inner foam of the helmet ,it will melt it into the perfet shape of the headset speakers :) :) :)
Active Member
WOW , Wish I had asked before doing mine..what a great Idea..:thumbsup:
Great tip,!
Oh - THAT guy...
I traced the speaker on the plastic and went at it (gently) with a dremel. Quick and easy. Just don't get aggr/strofoamessive...
used a hole saw on mine then used knife to remove inner pars for speakers,just make sure u measure 3 times cut once
Great tip, Wexy!
Discussion Starter · #8 ·
Not my strong point measuring. I usually measure several times and still manage to cut /drill wrong - I have shelves to prove it!
Vendor
Wexy, great inexpensive tip that works.
Since we install a couple thousand headsets a year at Sierra we use Diablo Forstner bits. A little pricey for a one time use but sure do a clean job. Most new helmets are a real pain even for us as most no longer are made like the old Arai, Shoei,or HJC with pockets to lay the speaker in. Manufacturers such as Shuberth only recommend a couple of installers, Sierra included, qualified to properly install headsets in their helmets.
Gregarious Greeter
[align=center]
[/align]
[align=center]Welcome austin allegro[/align]
1 - 13 of 13 Posts
