I want to lift the bike a few inches off the ground to be able to do a little maintenance such as cleaning the tires and adding sealant. I have a hydraulic lift with two arms. Does anyone know where the point is on the bike wher the frontto back weight ratio is 50/50? Thanks.
Check it yourself, it depends on how much junk in your trunk and saddle bags, how much fuel you have. Center of gravity, changes. How much lbs. of air in tires [lol]
try where the center stand is mounted first.
Monkey with a Football
This is for the 1500 but the same applies:
Click on the URL in my sig and then click on the Jacking link for pix.
Presitla99, I think it will be more a question of WHERE you are going to be able to lift it ratherthan the exact center of balance.. If you get those arms placed correctly & far enough apart you won't have to worry about the center of balance.. I think you will find it to bequite stable if you get those arms far enough apart..
Twisty
Twisty My lift is the same as Rudy's, The arms are not adjustable so we cant place them as far apart as possible.
Try starting out with the right arm just under the front of the engine, start the lift and watch to see if the bike comes up evenly. If one end or the other rises first, lower the bike, move the jack an inch or so toward the low end and try again. When you hit the right spot both wheels will come up the same height. That's the way I've done it many, many times with 1100s, 1200s, and three 1500s. The balance point varies with the junk in the trunk as has been mentioned along with accessories added and the amount of fuel in the tank so it's a trial and error deal each time.
