I got it for $265.00 US. It has 89000 miles on it with carbs etc. My plans are to do a slow leisurely bench restoration. Then slide it in and slide out the one I have for a rebuild. Soarise's existing go boxis at 89000 miles as well, is running strong etc.
But those miles are not my miles and I want to have a powerplant I know intimately. I also know myself and with my obsession with researching everything, this rebuild will not go fast and I do want to be on the road this summer!! If I pull Soarise's go box I can forget summer, fall and next summers rides!!!
I figure when I sell the original in rebuilt state I should recover a good deal of the total expense. I also expect I will be here quite often seeking advice as I rebuild both of them. Please bear with me, as I go through this.
Shipping will take a few weeks, does anyone have plans for an engine rebuild stand they would like to share? I am going to put the workshop in order now.
Other side of the pond
I think a stand is a waste of time. The Wing engines are odd in that you need to turn them over different ways several times when stripping them. Much easier on a flat bench and they are easy enough to manouvre that way. :)
Thank you, I will follow that advice. I used a vertical stand for the last VW I rebuilt and I found it of limited value.
It makes sense. An engine sand is fine fora car engine, save your money for parts for the engine. Lots of luck with the rebuild. :waving:
Parts price is an issue.
BTW, I come up to Lexington occasionally on business. May bring Soarise the next time.
Discussion Starter · #8 ·
I will be attempting to photograph the teardown
