Hi Folks, new to the forum here but have been checking out the vast amount of information available here. What a great resource this is.
Here is my situation. I just picked up a 1984 Goldwing Interstate with, according to the title, 57,000 miles. The previous owner had just purchased it at auction and had it shipped out from Florida to the West Coast. He said once it was off the shipping palate he started it up and came to life right away, he rode it at a low speed for a few minutes then parked it. I do believe him with regard to it being rideable, although this was four months ago.
Since then, the bike has been sitting outside in the rain, and it's been pretty wet in Seattle so far this year. I got it home, put in a new battery, turned the key, and all the lights worked fine.
I cranked it over, everything spun fine as well. However, it wouldn't start, not even a cough.
I put in new fuel, with seam foam.
I checked for spark, which was fine.
Still nothing.
Tried a little starting fluid, still nothing.
I then checked the compression, and found this:
LF: 140 psi
LR: 5 psi
RF: 140 psi
RR: 145 psi
I then put penetrating oil in the 5 psi cylinder, and after many cranks it crept up to 28 psi.
Here is my question for all of you venerable experts:
could this be a stuck valve, or more likely bad rings? If it's a valve, how to fix it, and if it's the rings, what might have caused the rings to go bad after sitting for only four months?
Thanks very much for any help you guys can provide!
Still nothing.
LF: 140 psi
LR: 5 psi
RF: 140 psi
RR: 145 psi
