Mike, this is the CRV remote;
[align=center]
[/align]
[align=left]The programming instructions are identicalto thosefor the GL1800 remote, I know because I have both units. You have to follow the instructions to the letter, sometimes a couple of attempts are needed. Note that in step 5 you need to programme your old remote as well (it's actually the bike you are programming to accept your remotes);[/align]
[align=left]1. Turn the ignition switch on - between one and four seconds and press the trunk "Pop-Up" button on the transmitter while aiming the transmitter at the trunk. Between one and four seconds, turn the ignition switch off. Note: keep the timing between one and four seconds, too fast or too slow will cause the control unit to lose the stored codes.
2. Between one and four seconds, turn the ignition switch on. Between one and four seconds, press the trunk " Pop-Up " button on the transmitter while aiming the transmitter at the trunk. Between one and four seconds, turn the ignition switch off.
3. Between one and four seconds, turn the ignition switch on. Between one and four seconds, press the trunk " Pop-Up " button on the transmitter while aiming the transmitter at the trunk. Between one and four seconds, turn the ignition switch off.
4. Between one and four seconds, turn the ignition switch on. Between one and four seconds, press the trunk " Pop-Up " button on the transmitter while aiming the transmitter at the trunk. Leave the ignition switch on.
5. Within 15 seconds, aim the transmitter (up to three) whose codes you want to store at the trunk and press the " Pop-Up " button once on each transmitter.
6. Between one and four seconds, turn the ignition switch off.
7. Confirm proper operation with the new code(s). [/align]
[align=left][/align]
[align=left]
BTW, the replacement remote shoud have FCC ID E4EG8DJ on the back. Also, I know that the older CRV remote (1997-99) work with the Wing, not sure about the later ones.[/align]
