Can someone tell me what size nut I need for my kickstand bolt. I was ckin over the bike and found that mine is missing. I would appreciate it if someone knows, otherwise I'll just yank it off and run to the Hardware store.
Thanks much
Dan
NUT, SIDE STAND
90203-MJ4-000
:?I bet its metric!!!
They gave the size of all other nuts and bolts,,,,,except this one:baffled:
Hey thanks for ckin. I guarantee it's metric but I was too lazy to go out to the shop and look in the manual. I thought maybe someone recently went thru this and remembered. No big deal. I'll yank it off and bring it with me to the hardware store.
Thanks much again
Dan
Dan, the nut it a 10mm fine thread. I don't remember the exact thread pitch. You might be best to order the nut from Honda. It's a very thin nut, not like a standard nut. It should be fine for a while without the nut, since the bolt threads into the back of the bracket behind the kickstand pivot point anyways. The nut on the rear is just a jam nut to stop the bolt from coming loose.
Hey thanks for that info. Now I wont worry about the bike falling over while I order one from Honda. Thanks again.
Dan
