The bike is a 2008 GL1800. I purchased the Kuryakan Pulsating Brake light. I am looking for the green and red wire under the seat, which I think I found. I used the light/continuity tester, and it blinks when I pull the brake, but once connected, the pulsating unit does not blink.
I am lost. See pics. I was so sure I had it all correct, I even installed the ground to the device. I disconnected the unit, and the ground wire is looking a little lonely.
This unit is supposed to handle up to 6 lights when connected from the under the seat location. I just reconnected the wire with a Posi-lock connector until one end fell into the innards of the motorcycle. I hope it will fall out one day.
Should I worry about it? The installation seemed so easy from the Kuryakan video. Is this the correct wire? Help!!!
