1 - 2 of 2 Posts
I've just brought a Kuryakyn Rear Wheel Ring of Fire Part # 7395, on the fitting instructions it says locate the peanut shaped vibration damper under the drive shaft remove the existing bolts and replace with the supplied studs and tighten to the correct torque value (refer to the factory service manual for this torque value) I have the service manual and I can't find a torque setting for this item (or indeed any reference to this vibration damper) is the torque setting critical ? and if so does anyone know what it is, thanks in advance
_________________
1 - 2 of 2 Posts
