1 - 11 of 11 Posts
I had disconnected the battery on my '96 1500A to put it on the BatteryTender for a few days. When I first reconnected the battery the LCD display didn't work for 5 or so minutes. Then it came on and worked fine the rest of the three hour ride.
Is this normal behavior for the LCD display after the battery has been disconnected for a several days, or signs of the LCD display going bad?
· Administrator
Piaggio MP3, was 02 GL1800
Personally, I do not disconnect the battery to plug in the Battery Tender. I have a permanent pull apart plug with fuse installed on the battery terminals and the plug hangs just outside the fairing forward of my foot.
I don't think you have a problem with the LCD panel, most likely just the ECM settling down after having the power restored.
YMMV though.
· Still Learning
As it is a 96, it could be dirty connectors to the speedometer unit. Does it keep accurate time?
YMMV though.
+1. We still have problems initializing radios on cars after swapping out a battery. Until it happens again, I'd be leaning toward a brain fart.
2000 GL1500SE
YMMV though.
Same as John except I have the plug in the right side cubby. I just open the cubby door and plug in my Battery Tender. Works great and no fuss.
YMMV though.
Yes, a permanent plug with fuse is definitely the way to go. I was planning to do that before I moved into an apartment complex, but now I need to bring the battery inside to do the Tending.
Discussion Starter · #8 ·
I'll keep my fingers crossed its just the ECM settling down.
Thanks all for your inputs.
· Administrator
the joys of apartment living.:lash:
Can't leave anything outside if you want to retain ownership of it.
· Still Learning
1 - 11 of 11 Posts
