I went out to try and look at my rear shocks for my other issue on my 1991 GL1500A Trike, and there was a puddle on the right side of the front wheel.
My question is, How hard of a job is it to change the front brake cables and then bleed the brakes? Is this something I need to take to the shop 3 hours away or can I do it myself?
I took off the rotor cover on the right side and wiped it down, and the leak seems to be coming from one of my cables, as the drip is dropping from the banjo bolt. I can see that one of the brake lines has been replaced with a braided stainless line and the other one is still a rubber line.
