The otherweek, the weather had warmed up a bit, enough that I thought I'd wander down to my unheated storage room and start readying my ride for the upcoming season. I have a 10 x 15 storage room holding all my woodworking equipment and I had to get 'creative' in order to get the bike in there.
I was lazy when I stored her at the end of last riding season and didn't do an oil change as I usually do, before layin her up. I open the storage room's roll up door to see my 'steed' waiting patiently for me.
I fired her up and let her come up to operating temps and then shut her off to let her cool down a bit, before changing the oil. In the meanwhile, I put a scissors jack with a piece of 1x2 on top of the jack,under the front of the engine, so I could pull the front wheel to get a new E3 installed on it. By that time the bike had cooled enough to dump the oil. It was getting on in the day and a buddy had dropped by, so I decided to just let her drain out good and come back in a day or two and finish it off. When I returned a few days later, I wasn't really dressed to work on the bike, as I was just dropping off some supplies. Ithought I'd just unscrew the filter and change it, then top her back up with the new oil. Simple job, right.
I dropped the oil then took off the old filter and struggled down beside the bike to install the new filter, tighten as much as possible by handand top her up with some fresh life giving Delo 400 15w40. I fired her up and let run for a few minutes, shut her down to check oil level. Perfect. Fire bike back up again to drain the full tank a bit for an upcoming low fuel level sensor install. Runs fine for 30 seconds and then there is this sickening 'gushing' sound. I immediately shut the bike off and there is oil all underneath the front of the bike, below the filter. What the He _ _!!! :?:?
After I get all the oil that is now flowingall overthe floor somewhat cleaned up,(wouldn't you know it, this happens as my buddy shows up and jokingly asks if he should call for theHAZ-MAT team :cooldevil
I get around to looking up at the offending oil filter and see that the O-ring is bulging out to one side :X
I remove said oil filter and discover to my amazement that there are 2 O-rings on it. One very deformed, hardened O-ring and the good one from the new filter. A quick check of the old filter confirms my suspicions where the offending O-ring came from. How it stayed put while I blindly wiped the filter mounting area, I don't know, but it did and it was a cause for a major PITA situation. I was just thankful that this happened here and now, instead of me out riding her and not being able to hear the gushing oil and causing some major damage to the engine!
Moral - check your old filter for it's O-ring still being intact, before installing the new one!
Dusty
Dusty
