i have an 1100 and was wondering if there are leds for it and if so what are they ?
yes there is and it depends where you what them. I have them on my 1100 and they are way brighter then stander bulbs. They are very low power lights. the only thing is you will have to get a different flasher if you put in blinkers. if you want to see a picture, ill show you.
I've replaced a number of bulbs on my 1100 and am happy with the results. +1 to changing the flasher. I use a 3-pin electronic flasher from the local auto sypply house.
Bringer of Shenanigans
I've switched out turn signals with LEDs. And added this to the rears.
http://www.electricalconnection.com/other-lighting/tsk-int.htm
It turns the saddlebag turn signals into running/brake lights. The red LEDs are super bright and do show red through the amber lens. It doesn't show as working on the 1100, but they do. Its just a small cluster of 4 LEDs per side.
hey tigger , what kit did you order ?
That's the generic LED model.
