1 - 15 of 15 Posts
hey all, I just got a new OEM left mirror But i cant figure out how to replace it. Ive seen people saying just to peel the boot back but thats impossible, the boot it so tight on there that i can only peel it back by ripping it. is there a secret to this? Im also replacing the headlight bulb, how do i access this? how many bulbs do i need. Should i get LED or Halogen?
(Rick Sheeley GWRRA)
If it's a GL1500, try poping the mirror trim first.
Thanks ken, it worked!! now about replacing my headlight bulb, should i get LED, HID or halogen? also, I heard you can "aim" it? how do you do that exactly?
Just Winging It
I live in the country and try not to ride at night But when I do I like to be able to see.
I tried the best ($$$) halogens and found I could not see good enough for night riding.
I installed a hid kit.
I aimed the light down and to the right.
There is glare due to the reflector being the wrong shape for hid.
I will be looking for a pair of hid driving lights (simulator to fog lights but for distance)
Once they are installed I think I'll go back to the single stock halogen bulb.
I find the HID helps people see me during the day much better than the stock bulb ever has.
I would not recommend HID because the glare is horrible and blinding to others on the road at night.
life is good
try the 55 watt silverstar ultra its a very bright white light i like em . and you can get them at a auto part store H4is the kind you get 2 of them also.
Oh - THAT guy...
I also like the Silverstar bulbs a lot! Replacements can be had at Wally World if needed so no issue if one goes out. My current set have been in a couple years and are great! I ride quite a bit at night.
Just Winging It
The 1500 has 2 bulbs the 1200 has only 1.
When my bike was new, I was amazed at how much better the headlight was compared to the standard round bulb on the 750F. I think a lot of it has to do with the reflector getting old and relatively dull. Now the beam seems dim, even with the Silver-Star bulb.
Oh - THAT guy...
Oh - THAT guy...
OK, so buy a pair (cheaper than one at a time) and you also have a replacement for the glove box if you feel the desire to tote it around.
Discussion Starter #13
When my bike was new, I was amazed at how much better the headlight was compared to the standard round bulb on the 750F. I think a lot of it has to do with the reflector getting old and relatively dull. Now the beam seems dim, even with the Silver-Star bulb.[/QUOis there anything you can do about a bad reflector? are replacements easy to find? okay 55 wat silver star it is!
No, there isn't much you can do about the reflector. You can open it up and wash the inside of the glass but the reflector is a very thin and delicate chrome coating. I tried to clean mine but Windex damaged it irreparably.
What's weird was, that didn't seem to change the beam.
1 - 15 of 15 Posts
