I have a 1995 Gl1500Se and I am trying to split the left handle bar switch assembly apart to replace the lite bulbs with no luck. I have removed the two bottom screws, but the the assembly only splits very little. Is there a trick or something I am missing?
Thanks,
Is the choke lever up? sometimes that can snag a bit when separating the 2 halves.
Moved choke lever either way, no help. The housing is very tight right under the high beam switch. Don't want to force and snap something off. I did the right side assembly lites with no issues.
DUHHHHHHH!! I found the problem. Somehow the ISO Grips I put on a few years ago had some rubber bond to the switch assembly.
