Here is how I was trained to fix em..
Get some clearcoat in a touch-up pen, at auto parts place.Lacquer is the easiest and most foolproof for a diy job.
Urethanes are a picky lot, and can go haywire,ie. fisheyes,crawling,etc..
Clean the area around, and the scratch, with Naptha or in a pinch, denatured alcohol will work. DON'T SCRUB!
Use a small piece of clean white cotton T shirt.
The plan is to get ALL the wax/silicone off the area.
Now carefully apply ONE coat of clear into the scratch, and let it dry COMPLETELY!
Then, you take some 600 or finer wet and dry sandpaper, and wrap it around a small piece of wood.
Dip the paper and block in some water and ever so carefully sand off the high areas caused by the new clear.
Keep doing this, coat of clear, let dry,wetsandsequence until the scratch is full and level with the surrounding finish.
The idea is to not sand through the clear, just the blobs left by application of the clear repair.
Once it is level, and you can't "feel" it,buff it up with some Dupont #7 Rubbing Compound.
If you need to talk to me, PM me and I can help you over the phone.
It's slow, but it works every time.
Sometimes you can thin the lacquer and "flow" it into the gouge, but if it takes too long to dry(too thick), it could attack your color coat,if you don't know what's under there for certain.
I'm sure the chemistry has changed since I painted cars/bikes in the 80's, but the techniques are basically the same.
Hope this helps you make it go away! jimsjinx:waving:
