Good Morning .... I have a problem on my 2000 1500 SE. During a ride on Saturday, I notice my fuel qauge, temp gauge, running lights and the lights around the trunk are not working. Also the OD light and reverse are not working. I'm sure there may be some others out too. I have checked the fuse panel, and all are good, that's the panelyou can get to easily but not the other fuse panel that you have to remove the saddle bag to get to. Am I proceeding in the right direction and if not, where do I need to check? I know the other fuse panel has several relays in it .... how do I tell if a relay is bad. Sure could use some help here.
