While changing the air filter, I see that a little liquid has accumulated at the back of the filter housing. About 50 cl ++
It was not clean water. Smell like gasoline and oil mixed with a little water.Is this normal?
Cause?
You need to drain the "Air Cleaner Housing Drain Tube. It is located behind the left side engine panel (alternator is behind this panel). You will see two tubes with a plug in the end of the tubes. Remove the plugs. You may only get some fluid from one of the tubes..
It is something that makes a little more strange, I had shortly before disassembly drained the hoses. Some water came out, but not much. Blown in the hoses to see that they were open. The liquid in the filter housing had a very low water content.
the liquid that was in the house was somewhat oily, a little tough.
