Below is the part of the link that pwhoever indicated.
That is what I have in mine and have had no problems! I just left the cover off....
"An easier solution and not very expensive is to replace the fuse with a "PAL" style fuse which is available at most auto parts stores. I ended up going with a 70 Amp one but they come in higher and lower amperage. They are a direct replacement for the dogbone fuse, easier to find if out on the road, and eliminate the stacking of several dogbone fuses so much safer. It only requires a slight mod to the fuse cover. A hole needs to be cut in a square so it will slip over the fuse after it is installed."
