Hello, there is 69,000 on the bike. I have a left side blown head gasket. I need to change the valve seals and timing belts at the same time. I will do both heads.
Questions, how do I know if I should do any thing to the cylinders also?
it should not need rings or anything also should it? How do I check for this before I start tearing it down? Would a compression test be accurate with a blown head gasket?
Thanks!
Randy
Chances are it will be fine unless it's been sitting a long time.
That was the first thing I had to do to mine when I bought it.
I recommend reading all you can about the carbs, and carb cleaning if it's been sitting a while.
Good luck the headgaskets, belts and carbs aren't too difficult just double check everything.
Thanks for the help. Actually been riding it for the last 30,000 miles so everything else OK.
if it was running fine untill the head gasket, i wouldnt worry about the rings or anything in the bottom end. unless you just have extra time and money that needs to be spent. i would do as you planned, head gaskets and belts. adjust the carbs after and enjoy the ride.
That is what I thought. Will removing the heads affect anything where the cylinder meets the case?
Banned
Here's the number from a guy in Houston that just told me few days ago that he has a bunch of head gaskets for sale and he was asking $25. His name is Dave and the number is 832-444-1969.
Since you are replacing the valve seals might as well lap the valves. It only takes 15 min. per head and the lapping paste is dirt cheap. I usually use a portable drill and I go slowly in both directions and you only need a few drops of paste per valve.
Thanks for the number.
