Hi all I just purchased a 1985 Aspencade with 6800 original miles and I need some input.
#1. I hardwired the stator wires and at just 6800 the plug and wires were already
showing signs of corrosion, should I do any other plugs ? What else should I look for?
#2. Speed sensor went out about 60 miles after I bought it, I pulled it off the wheel and
it had oil in it from a leaking fork seal, I spun the front wheel when I had the sensor off and the pin/shaft was turning so I am sure it is the sensor shorted out from the fork oil. Right ? LOL
#3. Carbs and all fluids were changed and cleaned rebuilt 2 years ago due to sitting and yep the carbs fouled up again but I changed the fuel filter and added some sea foam and it is getting better not perfect yet but very close, I looked in the tank and it is very clean except the sending unitor whatever those lines in the tank areseem to have some corrosion on the lines is this normal ?
#4. I got 2 matched painted helmets with the bike they are very decent but too small for me and the Mrs (sizes sm/med) they have the intercoms built in can I change the intercoms to different helmets and would the matched helmets be worth putting on ebay ?
I'm sure I'll have many more question in the future but I'll stop for now. Thanks in advance
for your help.
for your help.
