1 - 16 of 16 Posts
Good friend is selling me a 81 Goldwing, not the interstate version, with 71xxx miles for $700. When he put it in storage he turned the gas off, put fuel stabilizer in it and forgot about it for a year. When we tried to start it it immediately ran and he ran it at 3k rpms for about 3-5 min then it shut down. Now it will crank but it wont turn over. He said he will try it again tomorrow. Should I be concerned about anything?
Thanks.
turn off the fuel and crank it.. It may be flooded do to sticky floats.. If you get it to start up and run, turn on fuel and quickly tap on the float bowls. I would also get a can of seafoam and run a whole can threw it.
Before trying to restart it, pull the air cleaner and be sure you didn't suck in a mouse nest. They love to get in there.
I would also suggest dumping the fuel that's been in the tank and start with fresh.
what you mean by it will crank but not turn over?
is the engine spinning when you press starter.
try a few shots of starting fluid from an arosal. to see if it lacks fuel. check engine kill switch on right handlebar.
If you mean its a standard no fairing 81 it is much nicer and probly worth more than one with a fairing.
the fact of tha matter is a 81 goldwing not running would be only worth 300 to 400 dollars tops
wilf
Dumb, I know, but it happened to my Dad and he torn into the bike with reckless abandon only to relize hours later that the kill switch was off. Happened to me the other day and took about 5 minutes for me to relize what was going on.
Completely drained the battery of my first bike, an 84 Shadow, by trying to crank it with kill switch off. At least on the Goldwings it's more apparent - to me at least :)
Thanks for the tips. I'm headed up on Sat. to see if I can fix it myself before I commit to buying it.
sounds good
Don[t know the condition of the bike but just remember at 700 for the bike you are doing him a favour not getting a deal
Wilf
Silly question - Did he turn off the fuel tap when he put it into storeage?.... if so it may just need turning back on.
Otherwise check the air filter and put in fresh fuel.
Offer him $500 as is. You can always part out the bike and make some $$ if you can't get it running.
Tell him I'll give him $800.00 for it...If you are a true friend..Got a photo of it?:ROFL:eek:h but you said it wasn't an interstate forget it..
I'd go for the above. If it started and ran for a while and shut down without going bang then it's probably not terminal but you'll probably end spending money on gaskets and rebuild kits
Or let him get it running properly and pay the full amount. Never nice beating down a friend on a price but then he wouldn't want to stiff you with a non runner...hopefully
Check fuel filter could be clogged or fuel lines. Ive done the kill switch thing before, boy did I feel Dumb..Should have know better Good luck
Went For a Ride with the wife,the other day rode for a couple of hours and pulled over at a small place to get coffee and walk around. Got back on the bike and tried to start her up she would turn over but no fire.Then I notice that kill switch was off,My wife !! likes to grab hold of the handle bars to get on and had hit the kill switch took me a couple minutes to figure out what was wrong. Talk about feeling stupid DA! Good luck Hal
Assume you mean it ran at throttle setting of 3000rpm. for 3-5 min. then quit.?
Ditto Richardrwg , check for mice nests in air filter.
Drain old fuel if it smells bad , replace fuel filter.
Ensure you have good spark and check for hydrolock.
Check oil for gas contamination.
Tap all carb. bowls to loosen up floats.
If she starts , do Seafoam treatment to clear out the nasties.
1 - 16 of 16 Posts
