Steering head is the part of the forks that passes through the neck on the frame of the bike. There are some bearings that have to be torqued to a specified amount. Sometimes they loosen up. You can check for this by putting the bike on the center stand and raising the front wheel off the ground a bit. Then stand in front of the bike and pull and push (forward and backward) on both lower forks at the same time. If you get front-to-back movement, then the steering head bearings are out of adjustment. If you get no movement, the bearings are probably tight enough (even though they may not be to specification).
Be careful when pulling on the forks so that you don't pull the bike off the center stand.
