Thanks Ray, reason I posted wasn't for the whining so much as to compare notes and see what the problem is/was.
For me - I had a serious issue trying to seat both the seals with the tube in the triple clamps - I mucked with it for most of a day and finally dropped the tubes and pushed them home with a pvc tube. I dunno - everybody said it wasn't hard but I sure couldn't get any progress.
I need to check and make sure I didn't scar the tube.
About the oil, I have heard when using progressive springs - AIR can be left out, not the oil. the oil is what keeps it from being a pogo stick. Sticks? lol
Now about that oil,,,,,
when using progressive springs,,,,, the way the spring goes into the fork will change the level of the oil inside the fork, because of the differing winding rates - one side is closer spaced, and will displace more oil than the wide spaced end.
I'mmmmm wondering,,,,,,,,,,,,,,,,
EVERYBODY said getting the threads started into the tubes was a royal PITA when installing progressive springs.
- wana secret? before you put the spring into the tube,,,, put the cap on and find out where the threads start to engage. Note the position of the cap.
Install the spring and the cap. position the cap a few degrees counterclockwise to position where the threads start. push down evenly and turn about 90 degrees clockwise. IF the threads caught - the cap stays with the tube. (don't dawdle - put a couple more turns on the cap and get some threads holding) If not, try again.
I was thinking if checking the seal and oil etc - but I think I better order a couple new seals. The wipers should be ok.
I remember when I was a young buck, this ol biker dude used to put the old seal under the wiper kinda like a secondary wiper.
I'm think I need to go look for boogers on the tube - pray for me,,,, lol
(Just back - no appearant buggers on the tube. WHEW!
keep the shinny side up!
