Hello, this is my first time asking a question, I hope I'm doing it correctly.
My friend's GL1500 SE, Lehman trike conversion, is very slow backing up and won't climb any small hill like a garage apron. Following the factory manual I have found the battery is strong. I tested it with a battery load tester and voltmeter. The diagnostic procedure says to check the reverse resistor assembly using an ohmeter. The resistances should be between 0.12-0.17. I'm getting 0.3 between all three leads and the starter/reverse cable terminal. That seems to be twice as much resistance as specified.
The battery is less than 1 year old and has CTX24HL-BS printed on the front side.
What do you think of the resistances and do you have a suggestion of further testing?
Thanks in advance for your help
Bill:?
Bill:?
