I'm working my way thru recommended things to check that may be causing lowand inconsistent voltage readings. Typical sysmptoms go somthing like this-on a recent 250 mile ride down the interstate, in the first 125 miles the voltage reading fluctuated between 11.2 and 11.5. After stopping for gas and back up to speed, the reading held at 13.2 to 13.5 and never dropped. However,sometimes the readings will start in the 13's and drop slowly (15 minutes) into the 11's. On the 250 mile ride back, readings never got above 11.5. Battery is staying charged-voltage check between the batt terminals w/ engine off always reads in mid to high 12's.
I've put at least 2,000 miles on the bike since I've noticed these sysmptoms with no other problems, but I fear there is a lurking problem that will eventually bite me.
So far:
Alternator/stator checks ok
30 amp fuse checks ok
Ground wire from battery checks ok
3 yellow wire connector from alternator was eliminated years ago
Other connectors that posts recommend checking, check out ok
From other posts, it seems like the regulator/rectifier could be the cause. How do I go abouttesting it?
Thanks for a warm welcome to his new member-this site and the folks on it are great!
So far:
