Hi Stug, from one ex. Plymothian to a current one.....can you give a little more detail on your current 'Wing?...as I recall some models perhaps having lower saddlebag lights factory fitted, but not others...kits are available tho.
Cheers,
Peter.
Sorry if this question has already been answered, do the lower trunk lights work, if so how, what do I need to do to get mine working ?:)
If it is the 1500...the light did not come from the factory. Assuming you mean the side lights on the trunk. The refelectors in the saddlebags were just that ...reflectors. for the trunk light, a kit can be purchased to install incandescent bulbs. OR..you can add LED light strips with a little extra work.
This will add lights to the trunk side lights:
http://www.chromeworld.com/ProductD...ight+Kit&Referer=&Alias=&ptct=SGR-SR&CTitle=&
The thumbnail picture shows my Wing converted to LED light strips.
Also...here are some good "How To" descriptions from andother site.....
For the handle bar controls, I use 3mm blue LED's from superbrightleds.com. Also need 440 Ohm resistors to reduce voltage.
http://www.superbrightleds.com/cat/t...ge,3mm,18,166:
For the speedo..again from superbrightleds.com total of 4 lights to replace.
http://www.superbrightleds.com/morei...edge-base/200/
For the saddlebag and trunk light, I purchased from meritline.com. Had them on sale for 19.99 for a 3 meter strip.
http://www.meritline.com/waterproof-...--p-72360.aspx
Good "How to" documents on this site:
Controls
http://goldwingdocs.com/forum/viewtopic.php?f=14&t=9667
Dash lights
http://goldwingdocs.com/forum/viewto...p?f=14&t=10998
Saddlebags
http://goldwingdocs.com/forum/viewto...p?f=14&t=11057
if its a 1200 the bag lites from an sei or ltd can be used
i purchased some seperately several years ago and they can also be substituted for the middle rear reflector between the bag brakelights and used as running or a brakelight
