To help make the wife happy, and keep mefrom taking out another telephone pole!:shock:
I am going to install a kill switch to the sidestand. My Idea is to run a wire from the power line on the neutral light to a relay whichthe signal from the off/onswitch will berouted through in series with a switch I will mount on the frame for the sidestand to contact. That way when the relay loses power the loop to the runswitch will be broken. The problem is the relay will be energized whenever the bike is running. Not a good long term plan. Anybody got any ideas for making this work so that the relay is only energized when the system is in a no run mode?
I'll be in communicado until friday, gotta go to work!
