1 - 12 of 12 Posts
Lost on this *****
Well,, the season is upon us and for many of us we use this time to perform maintenance and upgrades on our beauties. So I thought I would post a few links with helpful tips for those that are new here and haven't seen them. Or even for a good refresher,,,,,,,,, ( I know I can'tremember all this info on here).
And please add to the list what you can
First is a tool I made for the Lock Nut on the Steering Head,,,,,,,,,,,,
http://goldwingfacts.com/forums/forum9/112668.html
This one gives you GRIP,,,,,,,,,,,,,,,,,,,
http://www.goldwingfacts.com/forums/forum1/108830.html
Happy Wrenching :waving:
Swing arm removal socket, I think this also works on the head but not sure if it is the same size or not.
5 mins. in the vice with an old socket and the angle grinder, then used the impact wrench with a firm push and off it came.
Just another ORF!
Good stuff/topic, Dave
Here's a 'tool' I made to remove the bottom bearing race out of the steering tube on my 1500.
You can read about it here; http://www.goldwingfacts.com/forums/view_post.php?post_id=1300209
My version of Exavid's fork spring tool, for when you have your forks removed from the bike and need to remove/install the fork caps
Here's another 'tool' I made, to remove a very stuburn fork cap. My fork caps are recessed hex sockets, so I just got a 17mm bolt, lock washer, a couple of nuts and ran a bead of weld around the top of the nut/bolt. Set it in the fork cap and hit it with my air gun and a deep 17mm socket. Presto ..... off it comes.
Speaking of fork caps Not a 'tool', but ...... If you don't have air valves in your fork caps, you can drill a hole and tap them, then install either an air valve, or a set of hex head button bolts (with washer/0-rings) This makes future fork oil changes a breeze as you now don't have to remove the fork caps to install fresh fluid.
I think that's it for my 'custom' tools. :baffling:
Dusty
Dusty
I like that idea. What kind of air valve; where would one get them?
Just another ORF!
Up here in Canada, you can get them from Princess Auto, which is very similar to your Harbor Freight!
A Google search should turn up something for you.
There was a similar thread about a year ago on making your own tools. So I have shown this before.
Nut with a Zerk or grease gun fitting threaded into it.
Attach it to gummed up brake calipers. A couple of squirts with a grease gun and out pop the pistons.
Lost on this *****
maplewingnut,,,,,,,,,,,,,, I've been here awhile, and I've never seen that one. So just goes to show that a lot goes on here, and if you blink,,,, you might miss some good stuff :thumbsup:.
Keep the ideas coming,,, I'm sure someone will benefit from it.
Lost on this *****
Just thought I'd give this a "Bump". I see a few members are talking about doing some of these jobs.
And maybe we can gain a few new ideas here :smiler:
MWG already helped me with that grease zerk for the brakes! And, it also came in handy on my gl1100 brake.
Thanks again Neil! Great tool!
A good subject considering the weird nuts Honda uses on their bikes.
That four prong tool is also used in removing the clutch cage on a CB750 SOHC. I think the nut is found on several Hondas.
My tool was made by a machinist friend after he found out the honda price. He also heat treated it. I mention this because if you grind too much on a socket tool, the heat may anneal the steel and soften it. Try to keep it cool anyway; less than 300-400F.
You're right Sandcast, there ARE a lot of weird nuts on Hondas. And the fittings they are put together with can be strange too!
:ROFL:
1 - 12 of 12 Posts
