1 - 11 of 11 Posts
Ole Guy
Decided to balance the carbs with a homemade manometer. Any good sources for making or purchasing the 5mm x 0.80 adpaters?
Ole Guy
Ole Guy,
I've seen this on the forum. Just done a search for "vacuum port adapters". Came up as the second one on the list. I would put the site here but I have trouble linking it. They are listed for $2.48 each and come with an O ring. The adapters are made in stainless.
Hope this helps. Terry
vencowings.com
Jim sells them and they come with the chokers to reduce oscillation if you are using vacuum guages.
Ordered mine from RB's link above. Good price, fast service and shipping.:clapper:
made my own with 3/16 break line a die 5mm x .80 some o rings and metric nuts
p.m. me if you want a set
second page of the reference and FAQ forum has a post with lots of info.
Ole Guy
Okay, I made some adapters out of some copper tubing I found. After reading the manual - Haynes - it says #4 is the base cylider. I messed with the adjuster on the left. The the one in the middle on the right. The idle ran up to about 1200 or 1300, so I lowered it to about 1000. I am not sure about the rear adjuster on the right side. If there is an order, I do know it. It is running better. Thanks for the tips on where to buy the adapters.
I made mine, too. I used #8x32 brass screws. Drilled a small hole through them, then cut the heads off. Screwed them in about 1/4 inch, then used a nut as a lock nut, finger tight. Plugged the hoses on the end sticking out.
I used 1/4" tubing (built my own) for my V-Star and used the old jets that came in the carbs when I upped the jet size. They pressed in there quite nicely and reduced the quick movements from the fluid.
1 - 11 of 11 Posts
