I have a 08 but it should be the same. Acording to the manual do the following:
1. Turn the Ignition switch to ON or ACC
2. Push the setup button once. "Clock Adjust" will display.
3. To set the hour, press and release the"INFO" button until the desired hour appears.
Quick Setting - push and hold the info button until the desired hour appears.
4. To set the minute use the "TRIP" button
5. Once the time is selected, push the setup button to enter the time.
When apox. 5 seconds pass without operating a button on the CLOCK ADJUST display, the display automatically returns to the previous display.
Be sure to push the setup button to enter your adjusted time in the system.
