1 - 13 of 13 Posts
Hi
I am new to this Forum and am impressed with the quality of the content. I have just bought the GL1200 as a Winter project. There is a lot to do. I felt dealing with the brakes first would at least allow me to stop the bike when I move it!
I am trying to remove the Master Cylinder. I have removed all fitments except the brake pipes.
Does anyone know how to get them off. I have tried a 10 mm spanner but am in danger of rounding off the heads.
Any suggestions would be most useful.
Thanks :jumper:
PS I have soaked them with Plus Gas
Welcome to the message board Rasputin. Do you mean the rear master cylinder under the side panel, or the equaliser valve under the forks? If its the EQ valve, you will probably have to use a vicegrips to get astart on the nuts and then a spanner to finish off. :waving:
Hi Joe
Thanks for the quick reply. It's the rear master cylinder. I didn't know about the equaliser valve. Are there any seals etc in it?
Regards
Rasputin, Just done the same job on my bike the tool you should use is called a "brake pipe flare nut wrench" and try not to round the nut it really does make the job a lot harder it also helps if you remove the plastic resevoir feed tube one small crosshead screw and prise it out this will give you a bit more elbow room at the master cylinder. Tas
generally, they are a pain in the... you know where. and you cannot get the pre-made pipes from honda (or at least one for the rear brake) so if you bugger them, you will need to make your own or have a machine shop do it for you.
Discussion Starter #12
I certainly will. I have booked the weekend with 'the BOSS' to deal with the braking issues on the Wing. Come what may I WILL have brakes by close of play Sunday?
:weightlifter:
Discussion Starter #13
MANY THANKS to all who helped with this problem. I have now fixed the brakes and all is well - on the brake front anyway! I managed to remove the master cylinder and found the seals were in perfect condition. The problem was the linkage to the front right hand caliper. Once bled everything fell into place. I renewed the all the seals on all calipers and the brakes are now fine.
Once again thanks
1 - 13 of 13 Posts
