1 - 20 of 28 Posts
Ok I admit I am a total sucker for a cool little gadget / gizmo that makes my life easier or tasks simpler so when I came across this I thought wow this sound perfect - But does it really work?
Since I did a search here on the forum and didn't find any mention of it I thought I would pose the question to everyone.
Have you ever heard of, seen or used one of these McCuff Motorcycle Fill gizmos? I don't know about everyone else but here in Mass the Vapor Recovery System is mandatory on all gas pumps and man do they make it difficult to fill up a bike! Actually the filling isn't the problem it's the topping off that is almost impossible without some overfilling / spilling.
http://www.mccuff.com
So let me know what you think before I order one :)
I know if Paul Sr. Says it works then it must be great right :D
I have never had any problem filling my tank to the brim. My concern with this gadget is that at some point fuel is going to get spilled on the unit and with continued use the pouch and unit will smell like fuel. It seems like the demonstrator would have taken the gadget out of the tank, while on the nozzle, rather than leaving it on the tank to get fuel on it. This gadgets gets a thumbsdown, just my.02
Keep on Winging:bat:
Piaggio MP3, was 02 GL1800
Thumbs down here.
That is a solution looking for a problem.
The chaos theory in motion. Create a problem where none exists, so you can provide the solution and make yourself look great.
No thanks.
Thumbs down here also. What a waste of time and money.
1993 gl1500, 1976 gl1000
Don't have an opinion good or bad. I just don't see a necessity so why spend the money.
Question is, on a custom bike like an OCC bike, where do you stash this thing in between fill-ups?
Would you want a gasoline smelling thing sitting in your trunk or saddlebag? Yuck...
Dark sunglasses and all them tattoos... what's up with that? Maybe too much pump time
The difficulty filling up the wing is being able to see the fuel level as it comes up to the filler neck. With this thing on you would lose any visual on the fuel level.
Plus the wing has a catch and drain in case of an overfill.
Thumbs down here.
Those vapor boots are a real pain, but I'd rather hold up it up than carry that thing.
Somewhere I've seen a metal device that is designed to help with this issue. It holds the vapor switch above the fill spout enough to look into the tank.
Itinerant Wing Preacher
Depends on whether you are in an area with the vapor recovery pumps or not.
I thought vaper nozzels were mandentory in all states by fed epa law.
Not here in the south. Jay
Just keep a small flashlight, wrapped in the small cloth you use to catch any drips after filling up. Even in daylight it's dark inside the tank, so if you want to get an additional quart or so, use the flashlight.
Houston, Dallas, San Antone, Ft. W, and Austin require them. Smaller towns don't. Thank goodness I am in Abilene because I hate those damn things.
We have them here in Maricopa County. Elsewhere in the state, they are not required. :X
My opinion on them is slightly lower than whale dung.
Now don't hold back let us know how you really feel:action::action: Jay
If ya can't pump gas, maybe riding a bike is not for you!! :DJust kiddin'! jimsjinx
Never had a problem myself even at night, with all the lights a gas stations and I fill her up to the top each time......
Well it is the good old USA and there has to be something said for being an entrepenuer..... I wish him the best with his product......
You can make one out of a piece of 1/8" aluminum. Cut a 2" square piece of aluminum, drill a 1/2" hole through the middle of it and cut a 1/2" slot from one side to each edge of the hole. Then when fueling, pull the foreskin back on the pump nozzle and slip the aluminum piece over the nozzle above the bump. I think 1/2" is the right size but don't remember because I lost the one I made. I really don't need one here the boot isn't common around these parts.
1 - 20 of 28 Posts
